Event Scope.Decode
Revision as of 16:15, 12 November 2013 by JonnyW (talk | contribs) (XML import for latest events)
<sidebar>Event Contents</sidebar> Sent when a block of the stream is to be decoded into packets
This event is part of the Scope class
HANDLE StreamH
The stream handle
ULONG TimeUS
The -ve offset from now of the earliest time to be decoded, in microseconds
ULONG OverlaySize
The number of microseconds of the decoded packet from its start
ULONG Non-zero if the data could be decoded
