Custom Interrupts - ARM
Revision as of 15:27, 21 January 2015 by BenR (talk | contribs)
<sidebar>Sidebar: What Is an Interrupt?</sidebar> Target ARM Processor ( AT91SAM7S128 )
(Note: For other ARM devices you may have to refer to the device datasheet to obtain the correct code)
The official device datasheet is an invaluable source of information when dealing with custom interrupts, as are two header files,lib_AT91SAM7S128.h and AT91SAM7S128.h, which provide functions and definitions. These files are applicable to all the devices in the AT91SAM7S range.
The header files can be found in the \Tools\ Global folder of the Flowcode installation. These files must not be modified!
Enable Code:
This command enables the receive interrupt of USART1.
AT91F_US_EnableIt(AT91C_BASE_US1,AT91C_US_RXRDY);
AT91F_US_EnableIt()
This library function can be used to enable any of the interrupts generated by a USART. AT91SAM7S16 and 32 devices have only one USART, the other devices in the range have two. The function writes to the interrupt enable register of the designated USART.
There is an AT91F_US_DisableIt() function that can be used in the same way in the Disable Code section to disable the interrupt.
AT91C_BASE_US1
This is the system definition of the base address of the registers associated with USART1
AT91C_US_RXRDY
This is the system definition of the RXRDY (Receive Ready) bit in a USART interrupt enable register.
Disable Code:
Handler Code:
This code section checks the identity of the peripheral device generating the interrupt and the interrupt event being generated. The Flowcode Custom Interrupt system receives two parameters when an interrupt is generated:
Peripheral device identity number (periphID)
Active interrupt flags (IFlags)
Active interrupt flags are those that have been both enabled and triggered.
if ( (periphID == AT91C_ID_US1) && (IFlags & AT91C_US_RXRDY) )
FCM_%n(); / Call Flowcode Macro
FCM_%n():
This is converted into the name of the macro selected in the 'Will call macro' box of the interrupt properties panel.
periphID:
This parameter is the system identification number of the peripheral device generating the interrupt. The following peripheral devices are supported by Flowcode as custom interrupts;
AT91C_ID_PIOA Parallel IO Controller AT91C_ID_ADC Analog-to-Digital Converter AT91C_ID_SPI Serial Peripheral Interface AT91C_ID_US0 USART 0 AT91C_ID_US1 USART 1 AT91C_ID_TWI Two-Wire Interface AT91C_ID_PWMC PWM Controller AT91C_ID_TC0 Timer Counter 0 AT91C_ID_TC1 Timer Counter 1 AT91C_ID_TC2 Timer Counter 2
IFlags:
This parameter contains all the interrupt flags that are being generated by the peripheral device and have been previously enabled.
AT91C_US_RXRDY:
In addition to being the definition of the interrupt enable flag, this also acts as the definition of the interrupt request flag.
