MLoader:Recent Changes
New in v3.2.1.5
Released Jan 2015
General
- Added return code for automation
- Corrected errors in chip CSV files (EEPROM locations, chipid)
- Improvements to stability
- Added timestamp output to trace functions
- Fixed various memory leaks
User Interface
- Corrected version number display
- Updated help file and moved to wiki
- Added links to website
- Added chip list for dsPIC/PIC24 devices
- Fixed autoscroll of output window
- Improvements to UI (buttons correctly disabled for appropriate targets)
- Improved reporting of errors
- Added missing menu items
- Progress bar functionality extended to other long operations
- Added a wait cursor for long operations
- User can now retry when problems occur in non-UI mode
- Added 'wrong chip' message if unexpected target is detected
Programming
- Fixed problems with ECIO/MIAC/etc. devices
- Fixed problems programming EB006 (legacy / v9) boards
- Added full support for dsPIC33E device on EB091
- Chip autodetect functionality added (EB006 / EB064)
- EEPROM reading added when receiving file
- UI-mode tx/rx functions hold chip in programming mode (consistent across targets)
- Added support for 18FxxK22 and 18FxxK50 devices
Known Issues
- mLoader is incompatible with the following chips:
- 10Fxxx
- 12F5xx
- 16F5x and 16F5xx
- 16F707 and 16F716
- 16F72x and 16F72xA
- 18FxxJxx
- The 18F13K50 and 18F14K50 chips may not work with older versions of EB006 - please contact technical support via the forum for more information.
