API Console.GetLineBytes
<sidebar>API contents</sidebar> Reads a line of bytes from the given console extending the array if needed
HANDLE ConsoleHandle
- A valid console windows handle
ULONG Line
- The zero-based index of the line to read the data from, pass -1 for final line
BYTE[] Buffer
- A buffer to read the data into
ULONG Offset
- An offset into Data of the first byte to write to
ULONG MaxBytes
- The number of bytes to read, -1 for full line
- The default value for this parameter is: -1
- Declare a variable 'result' of type ULONG
- Add to a calculation icon:
result = ::Console.GetLineBytes(consolehandle, line, _arraybuffer, offset, maxbytes)
