API File.Buffer.WriteArray
Revision as of 21:25, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Writes an array to the input stream
===Class hierarchy===File
Buffer
WriteArray
HANDLE FileHandle
The handle of an open file
ARRAY Data
An array of data to write to the file
ULONG Elements
Maximum number of elements to write
The default value for this parameter is: -1
ULONG
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.Buffer.WriteArray(filehandle, _arraydata, elements)
