Component: Servo Motor (BL0162) (E-blocks 2)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category E-blocks 2
Image Servo Motor (BL0162) component
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board. Provides up to eight individually addressable connections for standard DC servo motors to be connected.
DisableServo
Disables a servo channel effectivly disabling the motor.
BYTE Channel
The channel to set the position for. First channel is zero.
SetPosition
Moves directly to the specified position with no interpolation.
BYTE Channel
BYTE Position
Target position to move towards.
IsAutoMoving
Is the AutoMoveToPosition movement complete.
Returns 1 if the servo is still moving.
Returns 0 if the servo movement is complete.
This macro has no parameters
BYTE
MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
BYTE Channel
BYTE Position
BYTE : 1 = reached target, 0 = target not reached.
SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
BYTE Channel
BYTE Trim
0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us
AutoMoveToPosition
Automatically moves towards the new position with a fixed rate of 100 steps per second.
BYTE Channel
BYTE Position
Position to move to.
EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
BYTE Channel
SetAutoMoveSpeed
Sets the speed of the auto move to position macro.
Default speed is 1.
BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Sets up the servo motor interrupts
Simulation macro reference
Channels (1 - 8)
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::Channel_Count.
Set the number of servo's that you need to control.
Value from 1 to 8.
Channel 0
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin0.
Pin on which to output PWM for the servo motor.
Channel 1
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin1.
Channel 2
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin2.
Channel 3
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin3.
Channel 4
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin4.
Channel 5
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin5.
Channel 6
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin6.
Channel 7
This property is of type Single digital pin and can be referenced with the variable name Servo_Controller1::pin7.
Minimum (us)
This property is of type Unsigned integer and can be referenced with the variable name Servo_Controller1::min_pulse_width.
Shortest pulse width that will be used.
Maximum (us)
This property is of type Unsigned integer and can be referenced with the variable name Servo_Controller1::max_pulse_width.
Longest pulse width used for the PWM signals.
Trim 0
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim0.
Trim the pulse width for this channel. Use this to trim the positioning of two servos so that similar
input values will produce the same degree of movement.
Trim 1
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim1.
Trim 2
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim2.
Trim 3
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim3.
Trim 4
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim4.
Trim 5
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim5.
Trim 6
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim6.
Trim 7
This property is of type Fixed list of ints and can be referenced with the variable name Servo_Controller1::trim7.
Servo Object 0
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim0.
Drag a servo motor component onto the System Panel, and then select it here, to create
an on screen simulation of the way that your flowchart moves the servo's.
Servo motors should be based on the 'Servo Motor Base' component, or use a custom component
set to responf to 'User.Notify' events (ID = n/a, Data = Position (0-127)).
Servo Object 1
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim1.
Servo Object 2
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim2.
Servo Object 3
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim3.
Servo Object 4
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim4.
Servo Object 5
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim5.
Servo Object 6
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim6.
Servo Object 7
This property is of type Panel object and can be referenced with the variable name Servo_Controller1::sim7.
