Camera Control
Revision as of 16:00, 23 May 2018 by BenR (talk | contribs)
<sidebar>Sidebar: Flowcode Help Overview:Panels</sidebar>
There are two methods in which you can interact with the simulation panel; Camera and Cursor mode. It is a dynamic menu, and selecting the ‘Arrow’ icon will change the functionality of the three icons to its right.
Camera Mode You can pan (1), rotate (2) and zoom (3) the camera. To pan and rotate, hold the left mouse button and drag. To zoom, drag a box to the required size or use the mouse wheel to zoom in/ out. You can also zoom in/ out by scrolling the mouse wheel.
Cursor Mode Cursor Mode allows you to move (1), rotate (2) and scale (3) objects. When a shape is selected in cursor mode you will notice a set of ‘local’ axes appear on your shape. To ‘free move’ the object in the panel, left click and hold the object and drag. Alternatively, if you want to move your object along a constrained axis, left mouse click on these local axes and drag. Note; rotate and scale work in a similar way.
Axis alignment
You can use the 'Align Axis' button to mirror the axis of the selected object, this follows the alignment of the component axis, even when being manipulated and rotated.
The Preset Views button can also be used to manipulate the 3D panel camera.
Hint:
Video instructions
Note, the videos below are for Flowcode v6, however there are similarities so watching is still advised.
See the following Youtube videos to learn how to effectively control the camera and navigate the panels:
The Camera Control 1 video covers the basic camera controls and camera rotation and general camera manipulation.
The Camera Control 2 video covers slightly more advanced features such as using keyboard shortcuts as well as mouse movement to navigate the panel more effectively.
CERJCvyInV8}} uG20xwQtcCM}}
