Bot test
Revision as of 14:54, 10 August 2021 by DavidA (talk | contribs)
Macro References
StringRead
Returns the ASCII value of character idx of the Response string.
- Byte idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
- Byte Return
SendScript
Sends Script idx
Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent. Returns 0 for success and 1 for error
- Byte idx
Refers to the Script page to send (1-4).
- Byte Return
SendCommand
Sends the command buffer.
Returns 1 for success in sending the command. Returns 0 for errors.
- Byte ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
- Byte SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
- Byte Return
CreateCommandString
Assigns a string of characters to the Command buffer.
Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- String Data
This parameter may be returned back to the caller
- Byte Return
