Component: DAC (AD5662) (Analog Output)
Revision as of 12:42, 11 August 2021 by BenR (talk | contribs) (Overview)
Version 1.0 (Release)
Category Analog Output
Image DAC (AD5662) component
16-bit external DAC connected to the microcontroller using SPI.
Overview
The AD5662 is a 3V/5V general purpose SPI compatible, high-resolution digital to analog converter (DAC), capable of generating a rail-to-rail voltage output.
With 16-Bit resolution, the AD5662 is capable of finely tuning the voltage output across 65,536 steps, with an individual step voltage of 5/65536 = 0.0000763 volts DC.
The AD5662 requires an external reference voltage to set the output range of the DAC.
Pin reference from the datasheet:
AD5662_Demo
Circuit Diagram
OutputDAC
Outputs a value to the DAC,
UINT Output
Range: 0-65535 / 0=0V / 65535=VCC
Initialise the SPI bus ready for communications,
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimulateComms.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
