Bot test
| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Wireless |
GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
| DialNumber | |
| Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response. | |
| Number | |
| GetTextString | |
| Collects the text message data from an incoming text message. | |
| NumBytes | |
| [[File:]] - | Return |
| SendString | |
| Sends a string to the GSM module. | |
| Text | |
| SendScript | |
| Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx. | |
| idx | |
| SendCommand | |
| Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply | |
| Command | |
| SendCR | |
| AnswerIncomingCall | |
| Answers the phone for an incoming type call. Returns 0 for success and 255 for failure. | |
| GetTextNumber | |
| Collects the sender's phone number from an incoming text message. | |
| NumBytes | |
| HangUpCall | |
| Ends a voice based call. Returns 0 for success and 255 for failure. | |
| ReadString | |
| Copies the data from the data string array to a local string variable | |
| NumBytes | |
| SendTextMessage | |
| Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure. | |
| Number | |
| Message | |
| StringReceive | |
| Attempts to receive a string from the GSM modem. | |
| DeleteAllMessages | |
| Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail. | |
| CheckNetworkStatus | |
| Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM. | |
| CheckForIncoming | |
| Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing | |
| Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail. | |
