Bot test
| Author | Matrix Ltd. |
| Version | 1.4 |
I2C Master component
| Version | 1.4 (Release) |
More information on I2C can be found here,
Generic I2C EEPROM
Example file demonstrating how to read and write bytes from a generic I2C EEPROM device.
I2CEEPROM
Simulated I2C devices
I2C DS1307 Example
| ReceiveByte | |
| Receives a byte from the I²C bus. | |
| Last | |
| Used to signify the last byte when streaming incoming data. 0=Not last byte, 1=Last Byte | |
| Restart | |
| Outputs a restart condition onto the I²C bus. | |
| Stop | |
| Outputs a stop condition onto the I²C bus. | |
| Transaction_Uninit | |
| Uninitialise the I2C interface | |
| Start | |
| Outputs a start condition onto the I²C bus. | |
| Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called. | |
