Component: DAC (Internal) (Analog Output)
Revision as of 16:00, 27 August 2019 by BenR (talk | contribs) (XML import)
Version 2.0 (Release)
Category Analog Output
Image DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
SetOutput
Sets the output voltage of the DAC
UINT DAC_Value
The value to output to the DAC
Disable
Disables the DAC output.
This macro has no parameters
Enable
Enables the DAC Output.
Simulation macro reference
GetValue
Gets the Name property value
STRING Name
The name of the property
STRING
SetValue
Sets the Value for the named property
STRING Name
Name of property to update
STRING Value
The new value for the property
GetList
STRING Name
STRING
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
DAC Channel number
DAC Output Pin
This property is of type Single digital pin and can be referenced with the variable name PORT.
DAC Output Pin
Vref Option
This property is of type Fixed list of ints and can be referenced with the variable name VREFOP.
Vref Voltage
This property is of type Floating point and can be referenced with the variable name VrefVol.
Control Bits
This property is of type Signed integer and can be referenced with the variable name BITS.
Resolution
This property is of type Line of text and can be referenced with the variable name Res.
Voltage Resolution
This property is of type Floating point and can be referenced with the variable name VoltRes.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
