| Author
Matrix Ltd
| Version
1.1
| Category
Runtime Tools
Panel Console Viewer component
An easy way to display the data from up to four console windows on the panel.
SetText
| Allows the selected text to be specified.
- BYTE
Item
| 0=Title, 1=Col1, 2=Col2, 3=Col3, 4=Col4
- STRING
Text
GetText
| Allows the selected text to be read back.
- BYTE
Item
- STRING
AssignConsoleHandle
| Assigns a specific console handle to one of the text fields.
- BYTE
Item
| [[File:]] -
ConsoleHandle
SetColor
| Sets the selected item's color.
- BYTE
Item
| 0=Title, 1=Col1, 2=Col2, 3=Col3, 4=Col4, 5=Border
- ULONG
Color
AppendText
| Allows the text to be appended to without overwriting any existing text.
- BYTE
Item
- STRING
Text
- BYTE
AppendType
| 0=Start of Text, 1=End of Text
CheckBuffer
| Returns the number of values in the transmit or receive buffer
| [[File:]] -
Buffer
| 0=Transmit / 1=Receive
- UINT
ReceiveString
| Gets a string from the receive buffer
- UINT
MaxChars
- UINT
Timeout
| Time in milliseconds to wait for data
- STRING
| Initialises the UART component pins ready to send and receive data
ReceiveByteArray
| Receives an array of bytes and returns the number of bytes received.
- BYTE
Data
| A byte array variable to hold the received data
- UINT
NumBytes
| Maximum number of bytes to try and receive
- UINT
Timeout
| Max amount of time in ms to wait between bytes
- UINT
ReceiveString
| Receives a string of bytes and returns the number of bytes received.
- STRING
StringData
- UINT
NumBytes
- UINT
Timeout
- BYTE
Uninit
| Un-initialize the UART and release the resources
GetList
| Gets Named property List
- STRING
Name
- STRING
Delay
| Software UART Bit Delay
SetValue
| set Value of Named property
- STRING
Name
- STRING
Value
Uninit
GetList
- STRING
Name
- STRING
ReceiveByteArray
- BYTE
Data
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
ReceiveString
- STRING
StringData
- BYTE
NumBytes
- BYTE
Timeout
- BYTE
GetList
| returns Named property list
- STRING
Name
- STRING
Width
| Width of the console ripper component.
Height
| Heigth of the console ripper component.
Title Size
| Size applied to the title text font.
Text Size
| Size applied to the data text font.
Number Columns
| Sets the maximum number of consoles that can be displayed by the component.
Title Color
| Sets the colour of the title text.
Text1 Color
| Sets the colour of the data text 1.
Text2 Color
| Sets the colour of the data text 2.
Border Color
| Sets the colour of the border.
Show Title
| Decides if the title text is displayed.
Clear Old Data
| Removes old data from the console viewer when starting simulation if active.
Simulations
