Component: Modbus Master (SCADA) (Comms: System)
| Version | 2.1 (Release) |
| Category | Comms: System |
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount.
Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT SlaveID
- The ID of the MODBUS slave
- UINT RegAddress
- Address: 0=40001, 1=40002, ...
- UINT RegCount
- Number of consecutive registers to read, starting from RegAddress
ForceMultipleCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount.
- UINT SlaveID
- UINT CoilAddress
- Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
- UINT CoilCount
- Number of consecutive coils to try and read
- BYTE CoilData
- An array of bytes each containing 8 1-bit coil values
ForceSingleCoil
This command writes the contents of a discrete coil at the location CoilAddress.
- UINT SlaveID
- UINT CoilAddress
- BYTE CoilState
- 0=Off, 1=On
GetResponse
Collects as much incoming data as possible and stored into the response buffer. The number of bytes received will be stored into location 0 of the response buffer.
Return value indicates validity of incoming CRC. 0 = OK, 1 = CRC fail, 255 = No Data
ReadCoilStatus
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount.
- UINT SlaveID
- UINT CoilAddress
- UINT CoilCount
GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
- BYTE Index
- 0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, .....
ReadInputStatus
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount.
- UINT SlaveID
- UINT DataAddress
- Input Address: 0=10001, 1=10002, 2=10003, ...
- UINT DataCount
- Number of consecutive inputs to read, starting from RegAddress
ChangeFrameType
Default frame type is the type set in the component properties.
- BYTE Type
- 0 = Modbus RTU / 1 = Modbus ASCII
PresetSingleRegister
This command writes the contents of a analogue output holding registerl at the location RegAddress.
- UINT SlaveID
- UINT RegAddress
- UINT RegValue
- Value to send to the selected register
GetResponseInt
Reads a 16-bit value from the last received response.
The Index parametes specifies the byte index of the value to read back.
- BYTE Index
ReadInputRegister
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount.
- UINT SlaveID
- UINT RegAddress
- UINT RegCount
PresetMultipleRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount .
- UINT SlaveID
- UINT RegAddress
- UINT RegCount
- Number of consecutive registers to write, starting from RegAddress
- UINT RegValue
- Array of values to send to the registers
Starts up the UART to allow communications
Simulation macro reference
Frame Type
This property is of type Fixed list of ints and can be referenced with the variable name FrameType.
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
Slave ID Bytes
This property is of type Unsigned integer and can be referenced with the variable name AddressBytes.
Silent Interval
This property is of type Unsigned integer and can be referenced with the variable name SilentInterval.
Configures how much time to wait after each master modbus command before another command can be sent.
A silent interval of 60ms minimum is required in order to guarentee successful reception of the next transmission.
0=No Delay
60 = 60mS - Default
Range : 0 - 65535
UART Receive Timeout
This property is of type Unsigned integer and can be referenced with the variable name RXTOUT.
Amount of time to wait before timing out when listening for a slave's response.
Range: 0 - 255.
0 = Don't Wait
1 - 254 = X ms
255 = Wait Forever
Receive Timeout Count
This property is of type Unsigned integer and can be referenced with the variable name TOUTCNT.
Number of timeouts in a row to wait for until we decide the slave is not responding or finished responding
to a message.
Range: 0 - 255
0 = First Timeout Only
1 = First Timeout + 1
2 = First Timeout + 2
This property is of type True or false and can be referenced with the variable name scada_uart1::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name scada_uart1::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name scada_uart1::DataSource.
Simulation data source used to allow the component to connect to various remote devices
Nothing - Simulation data is ignored
COM port - Routes the communication data to and from a physical or virtual COM port
Injector - Routes the communication data via a data injector component on the Panel.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name scada_uart1::com_port.
Lists all the current available COM port hardware on your PC.
This property is of type Unsigned integer and can be referenced with the variable name scada_uart1::baud.
COM port data rate in bits per second
