Component: Injector (File) (Test Injectors)
Revision as of 19:47, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Test Injectors
Injector (File) component
Comms data injector to allow data to be streamed to and from a file during simulation. The component will read data from the incoming file and write data to the outgoing file.
Example to log the bytes sent via the UART RS232 component to a file as comma separated decimal numbers. LogToFile Contents of the file in the Flowcode project directory after running the simulation.
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
UARTSend
- BYTE Channel
- BYTE Data
Show Console
Incoming File
File to stream incoming data from. File -> Communications component.
Parse Mode
Specifies the way we read in the data from the file. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Display Mode
Specifies the way we show the data on the console. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Values Per Line
Number of values to display on a single line of the data console. 0 = Infinite number of characters
Skip Timestamp
A file populated with data from an injector may have a timestamp built in which we may not want to receive. Yes: Skip first 22 characters of each line of data so we don't receive any of the timestamp info. No: Read data normally.
Outgoing File
File to store outgoing data. Communications component -> File
Clear On Init
No - Append to the end of the file. Yes - Empty file on initialise and start from the beginning of the file.
Data Mode
Specifies how the data is represented in the outgoing file. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Values Per Line
Number of values to display on a single line, applies to the file and data console. 0 = Infinite number of characters
Append Timestamp
Appends a timestamp to the beginning of every line relating to the time the first byte in the line was received. Based on the PC system time. Timestamp in the format "YY/MM/DD - HH:MM:SS - "
Simulations
