| Author
Matrix Ltd
| Version
1.1
| Category
Servo Motor (Standard) component
Standard size servo motor suitable for control by the 'Servo Controller' component. Use the 'Link to...' property to attach other objects to the rotor for emulating mechanical systems. Send a virtual PWM signal to the servo by selecting it as a target of the 'Servo Controller' component.
SetTarget
| Set a panel object to be 'connected' to the servo's. The connected object will then move as if connected mechanically to the servo's actuator.
| [[File:]] -
Target
| Object to be moved by the motor
MoveToPositionInt
| Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE
| The channel to assign the new position. Range: 0-7
- UINT
Position
| Target position to move towards. Range: 0-65535
- BYTE
SetPositionInt
| Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
- BYTE
- UINT
Position
| Position to jump to. Range: 0-65535
MoveToPosition
- BYTE
- BYTE
Position
| Target position to move towards. Range: 0-255
- BYTE
SetTrim
| Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE
| The channel to set the position for. First channel is zero.
- BYTE
Trim
| Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
IsAutoMoving
| Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
- BYTE
SetAutoMoveSpeedInt
| Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
- UINT
Speed
| 1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
IsServoAutoMoving
| Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
- BYTE
| Servo Motor Output Range: 0-7
- BYTE
AutoMoveToPosition
| Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
- BYTE
- BYTE
Position
| Position to automatically move to. Range: 0-255
EnableServo
| Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE
SetAutoMoveSpeed
- BYTE
Speed
AutoMoveToPositionInt
| Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
- BYTE
- UINT
Position
| Position to automatically move to. Range: 0-65535
| Sets up the servo motor interrupts
WriteLEDs
| Allows control of all 8-LEDs on the front of the Formula Flowcode.
- BYTE
LED_Byte
| Starts up the formula flowcode PWM for motor control and performs the wait for button press
Link To...
| Select a panel object here to connect it 'mechanically' to the servo's actuator. The selected object will now be moved whenever the servo position changes. NB) To move multiple objects, first group the objects, and then select the group.
Reverse Output
| Some manufacturers motors may rotate in different ways to others. Changing this property allows you to flip the direction of the simulated motor to better match with the real world hardware.
Movement Type
Simulations
