Component: Data Sheet (Charts)
Revision as of 10:34, 17 November 2021 by Wiki bot (talk | contribs)
Author Steve Tandy
Category Charts
Data Sheet component
A component that accepts data that can then be viewed in a spreadsheet.
Clear
Resets the XY chart and removes all data points.
AddData
Add data to a spreadsheet. Returns true if ok.
[[File:]] - row
row for the data (1 - 32767)
[[File:]] - column
column for the data (1 - 255)
[[File:]] - data
the value to store in the spreadsheet
[[File:]] - Return
GetData
Returns the data from a spreadsheet row-column reference.
[[File:]] - row
[[File:]] - column
[[File:]] - Return
SetValue
Sets the component to the specified value.
[[File:]] - value
A new value for the component.
RefreshChart
Redraws the chart.
GetData
Gets a data point from the specified series.
- BYTE Series
Which series to add to (1-8)
[[File:]] - Index
The data point index (1 - 32767)
[[File:]] - Return
AddDataCXYY1
Adds a data point to a bubble chart.
- BYTE Series
- STRING Category
[[File:]] - Y
Y coordinate
[[File:]] - X
X coordinate
[[File:]] - Value
The value of the data point
GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
- STRING Name
- STRING Return
InitRXConfig
Initialization setting for RX Buffer Config
- BYTE Buffer
Buffer Number (0 or 1)
- BYTE Value
Config data byte
Uninit
Uninitialises the CAN, freeing its connections for general use
GetList
Get the Filter List of the Named Property
- STRING Name
- STRING Return
GetRxIdent
Generic function to get the received message Identifier.
- BYTE buffer
- ULONG Return
SetRxFilterStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages The messages are accepted if (StdID & Mask) == Filter
- BYTE Filter
Filter number
- BYTE Hi
The high byte (bits 8-15) of the ID
- BYTE Lo
The low byte (bits 0-7) of the ID
SetRxFilterExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages The messages are accepted if (ExtID & Mask) == Filter
- BYTE Filter
Send filter: 0 to 3
- BYTE ID3
The high byte (bits 24-31) of the ID
- BYTE ID2
The mid-high byte (bits 16-23) of the ID
- BYTE ID1
The mid-low byte (bits 8-15) of the ID
- BYTE ID0
Simulations
