Component: Image (2D Shapes)
Jump to navigationJump to search| Author | Steve Tandy |
| Category | 2D Shapes |
Image component
A basic image component for the 2d panel.
|   | GetValue |
| Reads Named property Value. | |
|  - STRING | Name |
|  - STRING | Return |
|   | Slave_Init |
| Initialise the Slave | |
|  - VOID | Return |
|   | Master_Disable_CS |
| Outputs a high signal to the chip select pin to deselect the remote slave device. | |
|  - VOID | Return |
|   | Master_Uninit |
| Uninitialise the Master | |
|  - VOID | Return |
|   | Master_Byte |
| Sends and receives a data byte | |
|  - BYTE | DataOut |
|  - BYTE | Return |
|   | GetConsoleHandle |
| Returns a handle to the console used by this component | |
| [[File:]] - | Return |
|   | Slave_TxByte |
| Sets the data to be transmitted to the SPI master. | |
|  - BYTE | Data |
|  - VOID | Return |
|   | Slave_RxByte |
| Returns the data received from the SPI Master | |
|  - BYTE | Return |
|   | SetValue |
| Change Named property to new Value. | |
|  - STRING | Name |
|  - STRING | Value |
|  - VOID | Return |
|   | SetPrescaler |
| Sets the prescaler value for the clock divider chain | |
|  - BYTE | Prescaler |
|  - VOID | Return |
|   | Master_Init |
| Initialise the Master | |
|  - BYTE | Return |
|   | GetList |
| returns Named property list | |
|  - STRING | Name |
|  - STRING | Return |
|   | Properties |
|   | Image |
|   | Filename |
|   | Vertical Alignment |
|   | Horizontal Alignment |
|   | Connections |
|   | Simulations |
