Component: RFID (MFRC522) (Wireless)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Author Ben Rowland and STibor
Version 3.0
Category Wireless
RFID (MFRC522) component
Functions designed to work with the MFRC522 contactless reader IC. The MFRC522 supports all variants of the MIFARE Mini, MIFARE 1K, MIFARE 4K, MIFARE Ultralight, MIFARE DESFire EV1 and MIFARE Plus RF identification protocols.
Here is a basic example program that reads the UID from a Mifare RFID tag and displays on an LCD. If the UID matches the UID stored in memory then a solenoid will fire allowing a door to be unlocked etc.
Display UID
Here is a basic example program to read and modify data stored on a Mifare RFID tag.
Read Write Test
CompareUID
Compares the UID from the ReadCardSerial macro with 4 byte UID. Returns 0 if the addresses match.
- BYTE Add0
- BYTE Add1
- BYTE Add2
- BYTE Add3
IsNewCardPresent
Is there a card present for us to communicate with. Returns 0 for no card and 1 for valid card present.
GetType
Translates the SAK (Select Acknowledge) to a PICC type
- BYTE sak
The SAK byte returned from PICC_Select
AntennaOff
Switches off the RFID antenna to save power. The antenna must be switched on again before communicating with an RFID tag.
ReadCardSerial
Simple wrapper around PICC_Select. Returns true if a UID could be read. Remember to call PICC_IsNewCardPresent(), PICC_RequestA() or PICC_WakeupA() first. The read UID is available in the class variable uid.
MifareWrite
Writes to a block of data on a MIFARE type tag
- BYTE BlockAddress
- BYTE Buffer
- BYTE BufferSize
Select
- BYTE ValidBits
StopCrypto
Used to exit the PCD from its authenticated state. Remember to call this function after communicating with an authenticated PICC - otherwise no new communications can start.
MifareRead
Reads from a block of data on a MIFARE type tag
- BYTE BlockAddress
- BYTE Buffer
- BYTE BufferSize
Authenticate
This command manages MIFARE authentication to enable a secure communication to any MIFARE Mini, MIFARE 1K and MIFARE 4K card. All keys are set to FFFFFFFFFFFFh at chip delivery. The authentication is described in the MFRC522 datasheet section 10.3.1.9.
- BYTE Command
PICC_CMD_MF_AUTH_KEY_A or PICC_CMD_MF_AUTH_KEY_B
- BYTE BlockAddress
The block number
- BYTE Key
Crypteo key to use
HaltA
Instructs a PICC in state ACTIVE(*) to go to state HALT
ReadUIDByte
- BYTE Index
0-9 = UID Data Bytes, 10 = UID Length, 11 = UID SAK
AntennaOn
Switches on the RFID antenna. Called as part of the Initialise macro.
Initialises the RFID module ready for interaction with RFID tags.
CardBitmap
Displays a monochrome bitmap read from the card on the LCD
- BYTE X
Range 0-127
- BYTE Y
Range 0-31
- STRING Filename
CardRecordMic
Records an audio stream on the card from the microphone
- BYTE BitDepth
0=8-bit, 1=16-bit
- BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
- UINT RecordTime
Time to record for in seconds, Range 0-65535
- STRING Filename
CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
- STRING Filename
Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
GetConsoleHandle
[[File:]] - Return
LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
- BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
LCDBacklight
Allows the LCD backlight brighntess to be adjusted
- BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDDrawRect
Allows a rectangle to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
- BYTE index
0=Left, 1=Right
ServoDisable
Allows one of the servo outputs 0-3 to be disabled
- BYTE Channel
Range 0-3
ServoEnable
Allows one of the servo outputs 0-3 to be enabled
- BYTE Channel
Range 0-3
CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
- STRING Filename
CardWriteByte
Appends a byte to the end of the currently open file
- BYTE Data
EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
- BYTE index
0=Left, 1=Right
SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
EncoderReset
Resets the motor encoder counters
LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
- BYTE State
0=Off 1=On
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Reset
MFRC522 Reset Pin
Simulations
API
