API Panel.Graphics.DrawText
<sidebar>API contents</sidebar> Draws a line of text texture
FLOAT X
- Initial horizontal position of text (depends on Align)
FLOAT Y
- Initial vertical position of text (depends on Align)
STRING Text
- The text to draw, may be multiple lines
BYTE Align
- The text alignment
Typical values for this parameter:
| Type | Name | Description |
| LONG | Align_TopLeft | Text is left aligned and drawn below the Y coordinate |
| LONG | Align_TopCenter | Text is center aligned and drawn below the Y coordinate |
| LONG | Align_TopRight | Text is right aligned and drawn below the Y coordinate |
| LONG | Align_CenterLeft | Text is left aligned and vertically centered |
| LONG | Align_Center | Text is horizontally aligned and vertically centered |
| LONG | Align_CenterRight | Text is right aligned and vertically centered |
| LONG | Align_BottomLeft | Text is left aligned and drawn above the Y coordinate |
| LONG | Align_BottomCenter | Text is center aligned drawn above the Y coordinate |
| LONG | Align_BottomRight | Text is right aligned drawn above the Y coordinate |
- Add to a calculation icon:
::Panel.Graphics.DrawText(x, y, "text", ::Panel.Graphics.Align_TopLeft)
