| Author
Matrix TSL
| Version
2.0
| Category
Environmental
Temp / Humidity component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
GetTemperatureReal
| Return temperature reading as a float value in degrees C
| [[File:]] -
GetTemperatureData
| Returns the raw register pair value
- UINT
GetTemperatureInt
| Return temperature reading as an integer value in degrees C
| [[File:]] -
GetHumidityInt
| returns the relative Humidity reading as an integer value
| [[File:]] -
GetHumidityReal
| returns the Humidity reading as a float value
| [[File:]] -
GetHumidityData
- UINT
| Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
- BYTE
Address
| Selects the correct device address based on the ADDR pin connection to VDD or VSS.
| Channel selection
SDA
SCL
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
Simulations
Simulation Comms
