Component: MIAC Bluetooth (MIAC: Addon Modules)
| Version | 1.0 (Release) |
| Category | MIAC: Addon Modules |
MIAC Bluetooth component
Bluetooth Addon for MIAC System
BluetoothCount
Returns the number of bytes waiting to be read from the receive buffer
BluetoothSendString
send string to Bluetooth module
- <- STRING Str
BluetoothChangeBaud
Changes the Bluetooth communication baud rate:
1 = 1200, 2 = 2400, 3 = 4800, 4 = 9600, 5 =19200, 6 =38400, 7 = 57600, 8 = 115200
(Applies to HC-06 module only)
- BYTE Baud
- New baud rate. 1=1200, 4=9600, 6=38400, 8=115200
BluetoothSetPin
Changes the pincode to a new value.
The passcode is four digits, e.g. 1234
- <- STRING Pincode
- New four digit pincode
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
BluetoothSetName
Changes the module Name to a new value.
- <- STRING Name
- New four digit passcode
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
BluetoothRead
Read one character from the Bluetooth module receive buffer.
Returns 0 if nothing in the receive buffer
BluetoothInitialize
Initializes the Bluetooth module (enables buffered receive mode)
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
- BYTE Terminal
- Terminal number to be read
BluetoothSend
Sends a character to the Bluetooth module
- BYTE Character
- Character (Byte) to send
Initialize
Forces a software reset on the module and enables buffered receive.
DigitalInput
Read the value of a terminal
- BYTE Terminal
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
This property is of type Unsigned integer and can be referenced with the variable name BAUD1.
