Component: MIAC GPS (MIAC: Addon Modules)
| Version | 1.0 (Release) |
| Category | MIAC: Addon Modules |
GPS Addon expansion module for MIAC System
FAT_OpenFile
- <- STRING Filename
GPS_Read_Longitude
GPS_Read_GroundSpeed
GPS_Read_Latitude
GPS_Read_DilutionOfPrecision
FAT_Init
GPS_Read_Over_Ground
GPS_Read_UTC_Date
- BYTE unit
GPS_HorizontalDilutionOfPrecision
FAT_ScanCurrentFolder
- UINT idx
- BYTE type
- Scan type
GPS_Is_Data_Valid
FAT_AppendStringToFile
- <- STRING Text
FAT_OpenFolder
- <- STRING Folder
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
FAT_MoveToNextFileSector
- BYTE force
- force next sector
FAT_ReadByteFromScan
- UINT idx
GPS_Read_NumberOfSatellites
FAT_ReadFileLength
FAT_CreateFile
GPS_Read_VerticalDilutionOfPrecision
FAT_WriteFileSector
GPS_Read_Altitude
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
FAT_ReadByteFromBuffer
- UINT address
FAT_ReadFileSector
FAT_WriteByteToBuffer
- UINT address
- BYTE data
FAT_DeleteFile
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
- BYTE Terminal
- Terminal number to be read
Initialize
Forces a software reset on the module
GPS_Read_UTC_Time
- BYTE unit
DigitalInput
Read the value of a terminal
- BYTE Terminal
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
