Component: Range Time of Flight (VL53L0X) (Light)
Revision as of 13:31, 17 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Light
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed. Detector
ReadModel
Collects the model number from the sensor
ReadRevision
Collects the revision number from the sensor
ReadDistance
Read the current distance in mm. Returns -1 if the sensor timed out during the read operation.
- INT Return
ReadRegister
A simple example showing a generic way to read a register using I2C.
- BYTE Address
WriteRegister
A simple example showing a generic way to write a register using I2C.
- BYTE Address
- BYTE Data
- BOOL Return
Range
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Injector
Simulations
Simulate Comms
