gLCD Object
Graphical LCD Object to draw the bitmap image to
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
ROM Bytes
Total number of ROM bytes used to store attached bitmap images.
Number of Bitmaps
Number of bitmaps the component can store and draw to the LCD. Min 1 / Max 10
Bitmap File
Bitmap file you wish to embed into the program. Compatible with .bmp files in the following formats: 24-Bit / 256 Colour / 16 Colour / Monochrome
File Colour Depth
Number of bits per pixel. Currently the component only supports bitmap files with 1-bit or 24-bit colour depth.
File Length
The number of bytes of ROM the bitmap file will consume. You can vie wthe number of ROM bytes available on your target device using the Device Helper component.
File Width
Width of the bitmap file in pixels
File Height
Height of the bitmap file in pixels
Data Offset
Offset in the file where the bitmap pixel data starts
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
Simulations
