Component: Rotary Switch (Switch)
| Version | 1.0 (Release) |
| Category | Switch |
A standard rotary switch with 4 digital outputs and 10 or 16 discrete positions.
GetPosition
Reads the current position of the rotary switch.
Simulation macro reference
SetPosition
Sets the current position of the rotary switch.
- BYTE Position
Num Positions
This property is of type Fixed list of ints and can be referenced with the variable name NumPositions.
Common Type
This property is of type Fixed list of ints and can be referenced with the variable name Common.
Pin 1
This property is of type Single digital pin and can be referenced with the variable name Pin1.
Pin 2
This property is of type Single digital pin and can be referenced with the variable name Pin2.
Pin 4
This property is of type Single digital pin and can be referenced with the variable name Pin4.
Pin 8
This property is of type Single digital pin and can be referenced with the variable name Pin8.
