Component: DAC (MCP4725) (MCP4725) (Analog Output)
Revision as of 16:30, 7 January 2022 by Wiki bot (talk | contribs)
Category Analog Output
DAC (MCP4725) component
Component to drive a 12-bit digital to analogue converter (DAC) IC from Microchip via an I2C interface.
COMMSA
SetOutput
Sets the output voltage of the DAC 12-Bit: Range 0-4095
- UINT DAC_Value
The value to output to the DAC
Disable
Disables the DAC output.
Enable
Enables the DAC Output.
Configures the I2C peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
Disabled Pull Down
Sets the pull down resistance when the IC's DAC output is disabled.
Vref Voltage
Steps
Number of discrete output states available from the DAC.
Control Bits
Resolution
Voltage Resolution
User Address Bits
Specifies the bottom three "user" bits of the I2C 7-bit address
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Simulations
Simulate Comms
DAC Output Scope Trace
API
