Component: Injector (Human Interface) (Test Injectors)
| Author | Matrix Ltd |
| Category | Test Injectors |
Injector (Human Interface) component
Comms data injector to allow typed data values to be inserted into a component. Allows data to be input in raw ASCII form or as numeric byte data 0-255.
FREE
This example receives a character via the RS232 component and outputs it to the LCD, an injector has been added to allow you to type data into the console.
Human Interface Injector Example
The Console window has tabs for the human interface data injector allowing you to type in data that will be received by the component.
Again the RS232 console tabs reflect the data as it is sent and received.
LCD showing received data.
| UARTBaud | |
| Channel | |
| Rate | |
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| UARTReceive | |
| Channel | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-53 | |
| State | |
| Range: 0-1 | |
| UARTSend | |
| Channel | |
| Data | |
| Sets up the injector ready to receive commands or send data | |
