API Panel.Position.GetBox
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Gets a handle to an object representing the components bounding box position
Class hierarchy
Panel
Position
GetBox
HANDLE Handle
The position or component to read from
HANDLE
Returns the handle to an object representing the components bounding box position
This call gets the objects bounding box position. This can be thought of as the objects size rather than its raw scale value.
The difference between scale and size only applies to objects with child objects, such as groups or compiled components.
Scale and size of the box
  • Add to a calculation icon:
    result = ::Panel.Position.GetBox(handle)
