Event DataRecorder.Decode
Revision as of 12:25, 16 January 2023 by Wiki bot (talk | contribs)
Decode
Sent when a block of the stream is to be decoded into packets
- HANDLE StreamH
The stream handle
- LONG TimeOffset
The -ve offset from now of the earliest time to be decoded
- ULONG Duration
The maximum number of ticks to decode into packets packet from the TimeOffset
- ULONG Return Non-zero if the data could be decoded
Details on using Event Macros can be found here: Event Macros
