Component: DSPBufferRef (DSP)
Revision as of 17:45, 9 November 2022 by Wiki bot (talk | contribs)
Category DSP
DSPBufferRef component
Reference and access to a specific DSP buffer inside another DSP component. Used for a DSP component input buffer.
Please click here for the component source code: FC_Comp_Source_DSP_Buff_Ref.fcfx
Prv_PutPropStr
- UINT Idx
- UINT Val
Prv_PutConsole
- UINT Idx
- ULONG Val
get
Embedded - Get/Set uses Type Specified to maintain efficiency Sim - Reverts to long type so 8/16 bit will also fit
- UINT Idx
- LONG Return
put
- UINT Idx
- LONG Val
put_float
- UINT Idx
- FLOAT Val
Prv_GetPropStr
- UINT Idx
Prv_GetConsole
- UINT Idx
- ULONG Return
SetHandle
- HANDLE Handle
get_float
- UINT Idx
- FLOAT Return
Link To
Subname
Subhandle
Buffer Size
Buffer Type
Console Handle
Text
Orientation
