Component: Dashboard lamp ()
Revision as of 17:45, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix
Version 1.1
Category
Dashboard lamp component
Indicator with bezel and label, particularly suitable for viewing on the dashboard. Indicator on/off colors, bezel color and label all editable via properties.
Please click here for the component source code: FC_Comp_Source_Dashboard_Indicator.fcfx
LED Resistor Calculator Tool
Fc9-type-5-icon.png Pin
Chip pin to connect the LED to.
Fc9-type-16-icon.png Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png On Color
The color of the indicator when it is turned on.
Fc9-type-1-icon.png Off Color
The color of the indicator when it is turned off.
Fc9-type-1-icon.png Bezel Color
Color of the bezel.
Fc9-type-1-icon.png Label Color
Color of the label text.
Fc9-type-10-icon.png Text
Text to show as the component label.
Fc9-type-3-icon.png Font
Font for the label text.
