Component: Colour Sensor (EBM018) (EBM Modules)
Revision as of 17:46, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.1
Category EBM Modules
Colour Sensor component
This board provides the ability to detect colours using the TCS3200 sensor. It will return RGB and W values, dependent on the colour of the object under test.
Please click here for the component source code: FC_Comp_Source_EBM018v2.fcfx
Sample program using the EBM018 - Colour sensor
Sets filter to RGB and W and reads values,displays on LCD
EBM018 Example
SetConfig
Sends the config data byte to the sensor using clock and data pins
- BYTE Data
SetLEDOn
Turn on the White LEDs
SetFrequencyRange
Dynamically change the sensor output frequency range to a new setting
- BYTE Freq
Percentage range (2,20,100)
GetFrequency
Samples and returns the sensor output frequency (Hz)
SetFilter
Dynamically change the sensor filter to RGB or W. Red = 0 Green = 1 Blue = 2 White = 3
- BYTE FilterColour
Filter Colour; Red = 0, Green = 1, Blue = 2 and White = 3
SetLEDOff
Turn off the White LEDs
Initialise the sensor configuration as set by the component properties
SDA
Pin used for sending serial configuration data to the sensor device
SCL
Pin used as clock pin for sending serial configuration data to the sensor device
Sensor Output
Pin used to monitor the output frequency from the light sensor
Output Frequency Range
Initial sensor output frequency range selection. 100% 0-500KHz 20% 0-100KHz 2% 0-10KHz
Filter Option
Initial filter selected
LED Control
Initial White LED state
Sample Time Period
Length of time period used to sample the sensor frequency (longer is more accurate)
