Component: Potentiometer (Analog Input)
| Category | Analog Input |
Potentiometer component
Please click here for the component source code: FC_Comp_Source_Potentiometer.fcfx
| ReadAsInt | |
| Read the ADC at full bit depth | |
| GetValue | |
| Get the Float value, between lower and upper bounds. Used on App Developer | |
| ReadAsFloat | |
| Reads the ADC as a direct voltage | |
| SetValue | |
| Sets the Float value, between lower and upper bounds. Used on App Developer | |
| Value | |
| ReadAsVoltage | |
| ReadAsByte | |
| Read the ADC as a byte | |
