| Author
Matrix Ltd.
| Version
2.3
| Category
Comms: Networking
WLAN ESP32 (Dummy) component
Wireless LAN component designed to work with ESP32 modules
Please click here for the component source code: FC_Comp_Source_WLAN_ESP32_Dummy.fcfx
Here is an example Flowcode program to send analogue data to a html web page.
The web page is set up to refresh every second
Instructions on how to change the refresh rate and access the web page is explained within the example file.
ESP Webpage
SocketConnect
- STRING
Address
- UINT
Port
- BYTE
SocketListen
| Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
- UINT
Port
- BYTE
ReadSSIDFromScan
| Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE
Index
| SSID Index
- STRING
CreateAccessPoint
| Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING
SSID
| Name of the wireless network to create
- STRING
Password
| Password used to gain access to the network
- BYTE
| 802.11 Channel Range 1-14
- BYTE
Encryption
| 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
ReadIP
| Collects the local IP address
- BYTE
Index
- BYTE
SocketWrite
- STRING
Buffer
- UINT
Size
- UINT
ReadSignalStrengthFromScan
| Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE
Index
| SSID Index
- INT
ReadEncryptionModeFromScan
| Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE
Index
| SSID Index
- BYTE
ConnectToSSID
| Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING
SSID
- STRING
Key
- BYTE
Timeout
| Number of seconds to wait for the connection, default 20
- BYTE
SocketOpen
| Returns 1 if socket sucessfully opened
- BYTE
SocketClose
AcceptOpen
| Returns 1 if there is an incoming connection on the listening port
- BYTE
ScanForSSID
| Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
- BYTE
SocketRead
- STRING
Buffer
- UINT
Size
- UINT
AcceptClose
| Close the socket associated with the Accepted incoming connection
| Initialise the WiFi system Returns 1 if successful Returns 0 if not
- BYTE
| Text label used to help identify the component on the panel.
Simulation Method
| Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
