| Category | E-blocks 2 |
Combo component
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs  and analogue inputs.
Please click here for the component source code: FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
|   | Seg_ShowDigit |
| Displays a digit on the 7-seg display |
|  - BYTE | Digit |
| Which of the digits to change (0 - 3) |
|  - BYTE | Value |
| The value to display (0 - 9) |
|  - BYTE | DecimalPoint |
| Decides if the decimal point is lit |
|  - VOID | Return |
|   | LCD_PrintFormattedNumber |
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295 |
|  - ULONG | Number |
| Enter the number or variable to print to the LCD |
|  - BOOL | Format |
| 0=Signed, 1=Unsigned |
|  - VOID | Return |
|   | LCD_RemapCharacter |
| Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.  The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map. |
|  - BYTE | RemapIdx |
| Remap Index, Range: 0 to (Remap Characters - 1) |
|  - BYTE | SearchCharacter |
| Character to look for a replace |
|  - BYTE | ReplacementCharacter |
| New character value to use in place of the search character. |
|  - VOID | Return |
|   | LCD_ScrollDisplay |
| Scrolls the display left or right by a number of given positions. |
|  - BYTE | Position |
| Holds the number of positions to shift the display |
|  - BYTE | Direction |
| 0 = left, 1 = right |
|  - VOID | Return |
|   | IO_SetPort |
| Sets the state of a single port |
|  - BYTE | Bank |
| 0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs |
|  - BYTE | Value |
|  - VOID | Return |
|   | IO_SetLEDState |
| Sets the state of a single LED |
|  - BYTE | Bank |
|  - BYTE | LED |
| 0 = LED0, 7 = LED7 |
|  - BYTE | State |
| 0 = Off, 1 = On |
|  - VOID | Return |
|   | LCD_PrintFloat |
| Print a Float number rounded up to a specified amount of decimal places. |
|  - FLOAT | Number |
|  - BYTE | DecimalPlaces |
| Enter how many decimal places to round up to (1 - 6) |
|  - VOID | Return |
|   | IO_GetPort |
| Reads the state of a single port |
|  - BYTE | Bank |
| 0 = Top Bank of Switches, 1 = Bottom Bank of Switches |
|  - BYTE | Return |
|   | LCD_Cursor |
| Moves the cursor on the LCD Display |
|  - BYTE | x |
| Set the cursor position in the X plane, 0 is the left most cell |
|  - BYTE | y |
| Set the cursor position in the Y plane, 0 is the top most cell |
|  - VOID | Return |
|   | Seg_ShowSegments |
| Allows the individual segments of the display to be controlled. |
|  - BYTE | Digit |
|  - BYTE | Segments |
| 8-bit Binary value to set the segments, bit0 = segA, bit1 = segB... |
|  - VOID | Return |
|   | LCD_Start |
| Startup routine required by the hardware device. Automatically clears the display after initialising. |
|  - VOID | Return |
|   | LCD_Command |
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet. |
|  - BYTE | instruction |
| Send a defined command to the LCD Screen. See datasheet for supported commands. |
|  - VOID | Return |
|   | LCD_RAMWrite |
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory |
|  - BYTE | Index |
| Values 0 to 7 |
|  - BYTE | d0 |
|  - BYTE | d1 |
|  - BYTE | d2 |
|  - BYTE | d3 |
|  - BYTE | d4 |
|  - BYTE | d5 |
|  - BYTE | d6 |
|  - BYTE | d7 |
|  - VOID | Return |
|   | IO_ReadAnalogAsInt |
| Reads one of the analogue components as an Integer value |
|  - BYTE | Channel |
| 0 = Light Sensor, 1 = Potentiometer |
|  - INT | Return |
|   | LCD_PrintString |
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro |
|  - STRING | Text |
| Enter the text or variable to print to the LCD |
|  - VOID | Return |
|   | LCD_ClearLine |
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data. |
|  - BYTE | Line |
| The line to clear, zero being the first (top) line of the display |
|  - VOID | Return |
|   | IO_GetSwitchState |
| Reads the state of a single switch Returns: 0 = Switch not pressed, 1 = Switch pressed |
|  - BYTE | Bank |
|  - BYTE | Switch |
| 0 = SW0, 7 = SW7 |
|  - BYTE | Return |
|   | IO_ReadAnalogAsByte |
| Reads one of the analogue components as an byte value |
|  - BYTE | Channel |
|  - BYTE | Return |
|   | LCD_PrintAscii |
| Takes the ascii value for a character and prints the character |
|  - BYTE | character |
| Holds an ascii value. |
|  - VOID | Return |
|   | LCD_PrintNumber |
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 |
|  - INT | Number |
|  - VOID | Return |
|   | LCD_RawSend |
| Sends data to the LCD display |
|  - BYTE | data |
| The data byte to send to the LCD |
|  - BOOL | type |
| A boolean to indicate command type: true to write data, false to write a command |
|  - VOID | Return |
|   | LCD_Clear |
| Clears the entire contents of the display. |
|  - VOID | Return |
|   | Properties |
|   | Connection Type |
|   | Bank 0 Connections |
|   | Bank 0 |
|   | Bank 1 Connections |
|   | Bank 1 |
|   | Analog Connections |
|   | Light Sensor |
| Light Sensor ADC channel Connected to Bank 0 pin 0 which is usually analog pin AN0. |
|   | Potentiometer |
| Potentiometer ADC channel Connected to Bank 0 pin 1 which is usually analog pin AN1. |
|   | Simulation |
|   | Analog Scope Traces |
| Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board. |
