| Author
Matrix Ltd
| Version
2.0
| Category
E-blocks 1
GLCD (EB076) component
Graphical display component designed to work with the Picaso range of displays from 4D Systems. Also available in the form of the EB076 GLCD Touchscreen E-block. Component based around the uLCD-32PT display.
Please click here for the component source code: FC_Comp_Source_GLCD_4D_EB076.fcfx
G4D_InitialiseCard
| Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure.
- BYTE
G4D_DumpScreenToFilePicaso
| Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- STRING
Filename
| Assigns the name of the file on the card to store the data.
- BYTE
G4D_ReadTouchCoordinatesPicaso
| Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
- BYTE
Axis
- UINT
G4D_GetTouchCoordinatesPicaso
| Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Returns a 1 if a press is detected. Returns a 2 if a release is detected. Returns a 3 if a moving drag is detected.
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
| Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
G4D_DisplayImageFromFilePicaso
| Attempts to print an image from the micro SD card using the specified filename on the card. The image is printed at location starting from X, Y. PosH and PosL specify the sector address of the previously stored image icon.
- UINT
X
- UINT
Y
- STRING
Filename
- UINT
PosH
- UINT
PosL
- BYTE
G4D_DisableTouchscreenPicaso
| Disables the touchscreen interface if available.
- BYTE
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
DisplayControl
| Controls the operation, contrast and backlight on the display
- BYTE
Backlight
| 0=Backlight Off, 1=Backlight On (default)
- BYTE
Display
| 0=Display off, 1=Display on (default)
- BYTE
Contrast
| Contrast Range 0 - 15
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
G4D_EnableTouchscreenPicaso
| Enables the touchscreen interface if available.
- BYTE
G4D_DisplayVideoFromCard
| Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BYTE
ColourMode
| Specifes the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
- BYTE
Delay
| Specifies the number of milliseconds to wait in between displaying each image.
- UINT
Frames
| Specifies the number of frames to display.
- BYTE
AddH
- BYTE
AddM
- BYTE
AddL
- BYTE
G4D_SetVolumePicaso
| Sets the playback volume.
- BYTE
Volume
| Volume = 0 - Mute Enabled / 1 - Volume Down 8 / 3 - Volume Down 1 / 253 - Volume Up 1 / 254 - Volume Up 8 / 255 - Mute Disabled / 8 - Minimum Volume Level / 127 - Maximum Volume Level
- BYTE
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
G4D_DumpScreenToCard
| Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height. The address parameters assign where on the card to store the data.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BYTE
AddH
- BYTE
AddM
- BYTE
AddL
- BYTE
G4D_SetVGADisplaySizePicaso
| Specifies the VGA display size in pixels. Size = 0 - 320 x 240 Resolution. Size = 1 - 640 x 480 Resolution. Size = 2 - 800 x 480 Resolution. Size = 3 - Custom Resolution
- BYTE
Size
- BYTE
ClearDisplay
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
G4D_DisplayImageFromCard
| Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BYTE
ColourMode
| Specifies the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
- BYTE
AddH
- BYTE
AddM
- BYTE
AddL
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
G4D_SetTouchRegionPicaso
| Specifies the area of the screen which will respond to touchscreen inputs.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
G4D_PlayAudioFromFilePicaso
| Attempts to stream an audio wav file from the micro SD card using the specified filename.
- BYTE
Play_Option
| Play_Option = 0 - Return when playing complete / 1 - Return immediatley / 2 - Stop Playback / 3 - Pause Playback / 4 - Resume Playback / 5 - Loop Playing until stopped
- STRING
Filename
- BYTE
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Reset Pin
| I/O pin connected to the reset signal on the gLCD
Baud Options
| Baud rate option selector
High Speed
| Determines if the baud rate is automaticaly switched from 9600 baud on initialise to 57600 baud. Only available in hardware mode.
Component Label
Component Label Scale
Physical Orientation
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
Display Method
