Component: GLCD Base (Graphical Library)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs)
Version 3.0
Category Graphical Library
GLCD Base component
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation. Suitable for inheriting to simplify the creation of further graphical LCD components.
Please click here for the component source code: FC_Comp_Source_GLCD_base.fcfx
Font sizes
Standard Fonts
0 = Normal
1 = 2 x Width
2 = 2 x Width and 2 x Height
3 = 2 x Height
Extended Fonts
4 = 2 x Width and 3 x Height
5 = 2 x Width and 4 x Height
6 = 2 x Width and 5 x Height
7 = 2 x Width and 6 x Height
8 = 3 x width
9 = 3 x Width and 2 x Height
10 = 3 x Width and 3 x Height
11 = 3 x Width and 4 x Height
12 = 3 x Width and 5 x Height
13 = 3 x Width and 6 x Height
14 = 4 x width
15 = 4 x Width and 2 x Height
16 = 4 x Width and 3 x Height
17 = 4 x Width and 4 x Height
18 = 4 x Width and 5 x Height
19 = 4 x Width and 6 x Height
20 = 5 x width
21 = 5 x Width and 2 x Height
22 = 5 x Width and 3 x Height
23 = 5 x Width and 4 x Height
24 = 5 x Width and 5 x Height
25 = 5 x Width and 6 x Height
26 = 6 x width
27 = 6 x Width and 2 x Height
28 = 6 x Width and 3 x Height
29 = 6 x Width and 4 x Height
30 = 6 x Width and 5 x Height
31 = 6 x Width and 6 x Height
EBM001 Basic Example
EBM001 gLCD Example File
FC6 Icon.png EBM001 Example
EBM001 Maze Builder
FC6 Icon.png Maze Builder gLCD
FC6 Icon.png 3D Manipulations
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-comp-macro.png DrawEnd
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png Ev_Initialise
Initialisation routine for the component once the component is linked to its parent
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Plot
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png DrawStart
Fc9-comp-macro.png FastPlot
Sets a pixel with the current foreground colour at current pixel location.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Specifies a specific window in the pixels to draw to.
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png ReadFontByte
Gets a byte from the selected embedded ASCII font data.
ASCII character for example 'A' or 65
Fc9-u8-icon.png - BYTE ByteIndex
Font column Ranging 0-4
Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png Pixel Width
Fc9-type-21-icon.png Pixel Height
Fc9-conn-icon.png Colour
Fc9-type-1-icon.png Foreground Colour
Specifies the initial foreground colour for shapes and text.
Fc9-conn-icon.png Bit Depth
Fc9-type-21-icon.png Colour Bit Depth
Fc9-type-21-icon.png Red Bit Depth
Fc9-type-21-icon.png Green Bit Depth
Fc9-type-21-icon.png Blue Bit Depth
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-7-icon.png Show Background Elements
Show or hide features like the title and background.
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Display Method
Fc9-type-7-icon.png Embed Font Set
Specifies if the font set is included with the embedded downloadable code. Some display types have in an built font and text functions so the embedded font set can be disabled to reduce code overhead. For other display types the embedded font data should be enable to allow the print functions to work correctly.
Fc9-type-21-icon.png Num Parents
Number of parent levels to jump up to get the auto title name. For most GLCDs it will be 1. For most Alpha LCDs it will be 2.
Fc9-type-7-icon.png Show GLCD Icon
Show the GLCD connectivity icon, Set to Yes for GLCDs and No for other none standard things e.g. Alphanumeric LCDs.
Fc9-type-21-icon.png TouchHandler
Fc9-type-16-icon.png Physical Orientation
