Component: LED (3mm, PCB) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
LED (3mm, PCB) component
An industry standard 3mm diameter LED. Any color may be chosen, and the leads trimmed to length.
Please click here for the component source code: FC_Comp_Source_LED_3mm.fcfx
