Component: Potentiometer (Slider) ()
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category
Potentiometer (Slider) component
Analogue slider with plastic cap and 100mm travel. Cap and marker colour can be changed in component properties.
Please click here for the component source code: FC_Comp_Source_pot_Slider.fcfx
Potentiometer Example
Tang Color
Colour of the moving part of the slider.
Marker Color
Colour of the marker line across the slider tang.
Body Color
Specifies the color of the slider body
Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
