| Author
Matrix Ltd
| Version
2.1
| Category
Alphanumeric
LCD (Electronic Assembly) component
Generic configurable alphanumeric LCD display component based on the OLED Hitachi like display controller ICs from Electronic Assembly wiith selectable 4/8 bit interface. These have a very slight timing difference from the standard Hitachi displays.
Please click here for the component source code: FC_Comp_Source_LCD-W162-XBLW.fcfx
Clear
| Clears the entire contents of the display.
PrintString
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro
  - STRING
Text
| Enter the text or variable to print to the LCD
PrintAscii
| Takes the ascii value for a character and prints the character
  - BYTE
character
| Holds an ascii value.
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
  - INT
Number
| Enter the number or variable to print to the LCD
RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
  - BYTE
Index
| Values 0 to 7
  - BYTE
d0
  - BYTE
d1
  - BYTE
d2
  - BYTE
d3
  - BYTE
d4
  - BYTE
d5
  - BYTE
d6
  - BYTE
d7
ClearLine
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data.
  - BYTE
Line
| The line to clear, zero being the first (top) line of the display
Cursor
| Moves the cursor on the LCD Display
  - BYTE
x
| Set the cursor position in the X plane, 0 is the left most cell
  - BYTE
y
| Set the cursor position in the Y plane, 0 is the top most cell
Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
  - BYTE
instruction
| Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
  - ULONG
Number
  - BOOL
Format
| 0=Signed, 1=Unsigned
ScrollDisplay
| Scrolls the display left or right by a number of given positions.
  - BYTE
Position
| Holds the number of positions to shift the display
  - BYTE
direction
| 0 = left, 1 = right
RawSend
| Sends data to the LCD display
  - BYTE
data
| The data byte to send to the LCD
  - BOOL
type
| A boolean to indicate command type: true to write data, false to write a command
PrintFloat
| Print a Float number rounded up to a specified amount of decimal places.
  - FLOAT
Number
  - BYTE
DecimalPlaces
| Enter how many decimal places to round up to (1 - 6)
Start
| Startup routine required by the hardware device. Automatically clears the display after initialising.
Interface mode
| Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency.
Data 0 (11 / 7)
| Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
| Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
| Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
| Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
| Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
| Enable pin - Used to synchronise data writes to the display
Use Read/Write Pin
| Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground.
Display Settings
Rows
| Number of lines of characters the LCD can display.
Columns
| Number of characters the LCD can display on a single line.
Display Simulation
Component Label
Component Label Scale
Text Colour
| Colour of the font characters drawn on the display
Text Background
| Colour surrounding the font characters drawn on the display
Display Background
| Colour of the background of the display
