| Author | Matrix Ltd |
| Category | Test Equipment |
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
Please click here for the component source code: FC_Comp_Source_PS2000.fcsx
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
 Velleman and Picoscope Demo
|   | ps2000_get_timebase |
| Returns details associated with the selected timebase index |
|  - INT | Handle |
| the handle of the required device. |
|  - INT | timebase |
| The ps2000a API allows you to select any of 2 32  different timebases based on a maximum sampling rate of 1 GS/s. |
|  - LONG | no_of_samples |
| number of samples required |
|  - LONG | time_interval |
| time interval between readings at the selected timebase. Use NULL if not required. |
|  - INT | time_units |
|  - INT | oversample |
| not used. |
|  - LONG | max_samples |
| on exit, the maximum number of samples available. |
|  - INT | Return |
|   | ps2000_open_unit_progress |
| This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope. |
|  - INT | handle |
|  - INT | Progress |
|  - INT | Return |
|   | ps2000_flash_led |
| This function flashes the LED on the front of the scope without blocking the calling thread. |
|  - INT | handle |
| handle of the scope device |
|  - INT | Return |
|   | ps2000_stop |
| This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data. |
|  - INT | Handle |
|  - INT | Return |
|   | ps2000_get_unit_info |
| This function retrieves information about the specified oscilloscope. |
|  - INT | Handle |
| the handle of the device |
|  - STRING | info_string |
| unit information string |
|  - INT | string_length |
| the maximum number of chars in the string |
|  - INT | info_line |
| a number specifying what information is required. 0=DriverVersion / 1=USBVersion / 2=HardwareVersion / 3=VariantInfo / 4=BatchAndSerial / 5=CalDate / 6=KernelVersion / 7=DigHardwareVersion / 8=AnHardwareVersion |
|  - INT | Return |
|   | ps2000_set_channel |
| This function specifies whether an input channel is to be enabled, its input coupling type, voltage range, analog offset and bandwidth limit. |
|  - INT | handle |
| Handle of the device |
|  - INT | channel |
| the channel to be configured.  The values are: 0=ChanA / 1=ChanB |
|  - INT | enabled |
| whether or not to enable the channel.  The values are: 0=Disable / 1=Enable |
|  - INT | dc |
| the impedance and coupling type. Values: 0=AC / 1=DC |
|  - INT | range |
| the input voltage range: 0=50mV / 1=100mV / 2=200mV / 3=500mV / 4=1V / 5=2V / 6=5V / 7=10V / 8=20V |
|  - INT | Return |
|   | ps2000_get_times_and_values |
|  - INT | Handle |
|  - LONG | times |
|  - INT | buffer_a |
|  - INT | buffer_b |
|  - INT | buffer_c |
|  - INT | buffer_d |
|  - INT | overflow |
|  - LONG | Return |
|   | ps2000_set_trigger |
|  - INT | handle |
|  - INT | source |
|  - INT | threshold |
|  - INT | direction |
|  - INT | delay |
|  - INT | auto_trigger_ms |
|  - INT | Return |
|   | ps2000_set_sig_gen_built_in |
| sets up the signal generator to produce a signal from a list of built-in waveforms |
|  - INT | Handle |
| Handle to the device |
|  - LONG | Offset_uV |
| the voltage offset, in microvolts, to be applied to the waveform |
|  - ULONG | pk2pk_uV |
| the peak-to-peak voltage, in microvolts, of the waveform |
|  - INT | waveType |
| the type of waveform to be generated. 0=Sine / 1=Square / 2=Triangle / 3=RampUp / 4=RampDown / 5=Sinc / 6=Gaus / 7=HalfSine / 8=DC |
|  - FLOAT | startFrequency |
| the frequency that the signal generator will initially produce |
|  - FLOAT | stopFrequency |
| the frequency at which the sweep reverses direction or returns to initial |
|  - FLOAT | increment |
| the amount of frequency increase or decrease in sweep mode |
|  - FLOAT | dwellTime |
| the time for which the sweep stays at each frequency, in seconds |
|  - INT | sweepType |
| whether the frequency will sweep from startFrequency to stopFrequency. 0=Up, 1=Down, 2=UpDown, 3=DownUp |
|  - ULONG | sweeps |
| produce number of cycles specified by shots |
|  - INT | Return |
|   | ps2000_close_unit |
| This function shuts down an oscilloscope. |
|  - INT | Handle |
| The handle of the scope device to be closed |
|  - INT | Return |
|   | ps2000_run_block |
| This function starts collecting data in block mode. |
|  - INT | handle |
|  - INT | timebase |
|  - LONG | time_indisposed_ms |
|  - INT | Return |
|   | ps2000_get_values |
| This function returns block-mode data, with or without downsampling. |
|  - INT | Handle |
|  - INT | buffer_a |
| Start point for data collection |
|  - INT | buffer_b |
| Number of samples |
|  - INT | buffer_c |
| Down sample ratio |
|  - INT | buffer_d |
| Down sample mode : 0=None / 1=Aggregate / 2=Decimate / 4=Average |
|  - INT | overflow |
| Flags to indicate if an overflow has occurred |
|  - LONG | Return |
|   | ps2000_ready |
|  - INT | Handle |
|  - INT | Return |
|   | ps2000_open_unit_async |
| This function opens a scope without blocking the calling thread. |
|  - INT | Return |
|   | ps2000_open_unit |
| Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open |
|  - INT | Return |
|   | Properties |
