Component: Property Manager (Utility )
| Category | Utility |
Property Manager component
Allows property values exposed to the user to be saved and loaded using an external file. Simplifies the process of storing and retreiving the property values. Also works with nested properties using the "::" syntax.
Please click here for the component source code: FC_Comp_Source_PropertyManager.fcsx
| Save | |
| Saves the registered property values to the config file. | |
| Load | |
| Loads the registered property values from the config file. | |
