| Author
Matrix Ltd.
| Version
2.2
| Category
Comms: Networking
TCP Template component
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation. Suitable for inheriting
Please click here for the component source code: FC_Comp_Source_TCPIP_Base.fcfx
Additional examples can be found in the “Apps and Bundles” section of this Wiki:
 Internet Application Guide
 Wireless LAN Application Guide
TxSendMyIP
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
  - BYTE
| Specifies the communications channel 0-3
RxMatchMyIP
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
  - BYTE
  - BYTE
RxMatch_4_Bytes
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters.  There are similar functions that check for 2 bytes and 6 bytes.
  - BYTE
  - BYTE
Byte1
| Specifies the value of the first byte
  - BYTE
Byte2
| Specifies the value of the second byte
  - BYTE
Byte3
| Specifies the value of the third byte
  - BYTE
Byte4
| Specifies the value of the fourth byte
  - BYTE
SetPropertyVal
  - STRING
Property
  - STRING
Value
SetMyIP
| This macro sets up the Internet E-Block's own IP address.  In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
  - BYTE
IP0
| First Byte of IP address
  - BYTE
IP1
| Second Byte of IP address
  - BYTE
IP2
| Third Byte of IP address
  - BYTE
IP3
| Fourth Byte of IP address
TxSendString
| This macro fills the specified channel's transmit buffer with data.  It can fill the buffer with a single byte of data, or with a string of information.
  - BYTE
  - STRING
Data
| Data byte to append to Tx buffer.
SecureWrite
| Attempts to write max number of bytes to the secure socket from the buffer. Returns actual number of bytes written.
  - STRING
buffer
  - INT
max
  - INT
Connect
| Attempt to connect to the given address and port. First open a socket on the local device using the Socket function and check that it is successful.
  - STRING
Address
| Remote destination address
  - UINT
Port
| Remote destination port
  - BYTE
ForcePropEvent
| Allows the property event to be fired, doing things like fetching the correct IP for the network interface.
Receive
| Receive data into the data buffer. Returns the number of bytes received
  - STRING
Data
| Data byte buffer to receive the data
  - UINT
Count
| Maximum number of bytes to read
  - UINT
SendTo
| Send data to a destination host. Returns the number of bytes sent.
  - STRING
Data
| Data byte buffer to send
  - UINT
Count
| Number of bytes to send
  - STRING
Address
  - UINT
Port
  - UINT
SecureConnect
| Connect securely to host and port. e.g. “www.bbc.co.uk:443” Returns 1 if successful, 0 if not
  - STRING
host
| Host:Port as string
  - INT
RxReadHeader
| Once data in a particular channel has been received, the header will be filled with information about the received data.  This macro will return the information in the header.  The idx parameter specifies which byte of information in the header to read
  - BYTE
  - BYTE
Idx
| Specifies the byte index to return
  - BYTE
RxSkipBytes
| Often when receiving data packets, it may be necessary to ignore large sections of the data.  This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
  - BYTE
  - BYTE
Count
| Specifies how many bytes to skip
CreateIPSocket
| Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3.  Note that sockets with different modes can be opened on different channels.
  - BYTE
  - BYTE
Protocol
| Specifies which IP protocol to use
  - BYTE
Broadcast
| Allows broadcast type packets to be sent and received
  - BYTE
SetDestination
| This is used in IP and UDP modes to set the destination of the intended data transfer.  The destination IP address needs to be set for both IP and UDP modes.
  - BYTE
  - BYTE
Dst_IP0
| Specifies the first byte of an IP address
  - BYTE
Dst_IP1
| Specifies the second byte of an IP address
  - BYTE
Dst_IP2
| Specifies the third byte of an IP address
  - BYTE
Dst_IP3
| Specifies the fourth byte of an IP address
  - BYTE
Dst_Port_Hi
| Port High Byte
  - BYTE
Dst_Port_Lo
| Port Low Byte
GetConsole
| Obtain the console instance for the TCP/IP base.
  - HANDLE
TxStart
| This macro indicates the start of data transmission for the specified buffer.  In TCP mode, data transmission can only begin once the socket has become established.  In other modes, data transmission can occur as soon as the socket has been opened.
  - BYTE
RxReadByte
| A call to this macro will return a byte of data in the reception buffer of the specified channel.  It will also internally increment a pointer to that data so that the next call to 'RxReadByte' (or any other read function) will read the next byte
  - BYTE
  - BYTE
CreateUDPSocket
| This macro creates a socket for sending and receiving UDP data.
  - BYTE
  - BYTE
Src_Port_Hi
| Port High Byte
  - BYTE
Src_Port_Lo
| Port Low Byte
  - BYTE
Send
| Send data
  - STRING
Data
  - UINT
Count
  - UINT
RxMatch_6_Bytes
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters.  There are similar functions that check for 2 bytes and 4 bytes.
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
Byte3
  - BYTE
Byte4
  - BYTE
Byte5
| Specifies the value of the fifth byte
  - BYTE
Byte6
| Specifies the value of the sixth byte
  - BYTE
RxMatch_2_Bytes
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters.  There are similar functions that check for 4 bytes and 6 bytes.
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
SecureClose
| Close the secure connection
RxReadString
| A call to this macro will return a byte of data in the reception buffer of the specified channel.  It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
  - BYTE
  - BYTE
Length
  - STRING
TxEnd
| Once the transmit buffer has been filled with data, call this macro to actually send the data.
  - BYTE
SetChannel
| Dictates the TCP IP channel used for socket communications allowing for multiple parrallel communication streams to co-exist, Used by the network comms component to drive the TCP IP runtime comms
  - BYTE
| Range: 0 to 3
Listen
| Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful.
  - UINT
Port
  - BYTE
CreateTCPSocket
| This macro creates a socket for sending and receiving TCP data.
  - BYTE
  - BYTE
Src_Port_Hi
| Port High Byte
  - BYTE
Src_Port_Lo
| Port Low Byte
  - BYTE
RxDataAvailable
| This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received.  A positive return value indicates that data is available.
  - BYTE
  - BYTE
SocketOpen
| Attempts to create a socket on the local device. Type =0 for TCP, =1 for UDP This must be successfully done before attempting connection with a remote destination. Returns 1 if successful, 0 if not.
  - BYTE
Type
| Type of socket to create
  - BYTE
TxSendByte
  - BYTE
  - BYTE
Data
TCPListen
| This macro puts a previously opened TCP channel in "passive open" mode.  This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
  - BYTE
RxFlushData
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
  - BYTE
TCPConnect
| This macro puts a previously opened TCP channel in "active open" mode.  This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
  - BYTE
  - BYTE
Dst_IP0
  - BYTE
Dst_IP1
  - BYTE
Dst_IP2
  - BYTE
Dst_IP3
  - BYTE
Dst_Port_Hi
| High Byte of destination port
  - BYTE
Dst_Port_Lo
| Low Byte of destination port
  - BYTE
GetPropertyVal
  - STRING
Property
  - STRING
SocketClose
| Close the socket
SecureRead
| Attempts to read max number of bytes from the secure socket into the buffer. Returns actual number of bytes read.
  - STRING
buffer
  - INT
max
  - INT
RxMatchMyMAC
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
  - BYTE
  - BYTE
AcceptOpen
  - BYTE
RxDataSize
| This macro is used to detect the size of data collected by the Rx_data_available macro.
  - BYTE
  - BYTE
TxSendMyMAC
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
  - BYTE
CreateMACSocket
| This macro creates a socket for sending and receiving Ethernet data using raw data.
  - BYTE
Promiscuous
| Receive everything (1) or just data bound for your MAC (0)
  - BYTE
Broadcast
| Allows broadcast messages to be accepted (1) or rejected (0)
  - BYTE
Error
| Allowsmessages with errors to be accepted (1) or rejected (0)
  - BYTE
AcceptClose
| Close the accept socket
SecureInit
| Call once to initialise the secure socket funtionality
GetSocketStatus
| This returns the state of the requested channel's socket.
  - BYTE
  - BYTE
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros
TCPClose
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
  - BYTE
Hostname
| Local PC's hostname
Network Interface
| List of network interfaces connected to the PC.  Sets which interface we are communicating via.
Gateway IP
Gateway0
| Gateway IP address to the Internet, auto populated from the selected interface.
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
| Network IP subnet mask, auto populated from the selected interface.
Subnet1
Subnet2
Subnet3
IP Address
IP0
| Network IP address, auto populated from the selected interface.
IP1
IP2
IP3
MAC Address
MAC0
| Network MAC address, auto populated from the selected interface.
MAC1
MAC2
MAC3
MAC4
MAC5
Notify
| Generate Console Data
Target
| Sets a target object, to which User.Notify events will be sent when data is sent and received. Events are send with Message ID = this component's handle,  Data: 1=Send, 2=Receive.
