Component: API (BL0032) (API Slave Devices)
| Version | 2.1 |
API (BL0032) component
Connects to an BL0032 dsPIC running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to view the component source code (Beta): FC_Comp_Source_BL0032_API_Comp.fcfx
The App Developer (BL0032 dsPIC E-Block) component allows an BL0032 dsPIC E-block board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
BL0032 dsPIC App Developer Firmware
The USB should be connected to the Target port on the E-block board to allow Flowcode to communicate with the Target microcontroller.
The COM port to the E-block hardware is selected via the SCADA_BL0032 component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
Here is a table showing how the slave digital pins are mapped on the device.
| App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 | 42 | 43 | 44 | 45 | 46 | 47 |
| Device Port Pin | B0 | B1 | B2 | B3 | B4 | B5 | B6 | B7 | B8 | B9 | B10 | B11 | B12 | B13 | B14 | B15 | D0 | D1 | D2 | D3 | D4 | D5 | D6 | D7 | E0 | E1 | E2 | E3 | E4 | E5 | E6 | E7 | F0 | F1 | F3 | F4 | F5 | C13 | C14 | D8 | D9 | D10 | D11 | G6 | G7 | G8 | G9 |
Here is a table showing how the slave analogue pins are mapped on the device.
| App Developer Slave Analogue Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 |
| Device Port Pin | B0 | B1 | B2 | B3 | B4 | B5 | B6 | B7 | B8 | B9 | B10 | B11 | B12 | B13 | B14 | B15 | E0 | E1 | E2 | E3 | E4 | E5 | E6 | E7 |
Here is a table showing how the slave peripheral pins are mapped on the device.
| App Developer Slave Peripheral Pin | I2C 0 SDA | I2C 0 SCL | I2C 1 SDA | I2C 1 SCL | SPI 0 MOSI | SPI 0 MISO | SPI 0 SCK | SPI 1 MOSI | SPI 1 MISO | SPI 1 SCK | SPI 2 MOSI | SPI 2 MISO | SPI 2 SCK | SPI 3 MOSI | SPI 3 MISO | SPI 3 SCK | UART 0 RX | UART 0 TX | UART 1 RX | UART 1 TX | UART 2 RX | UART 2 TX | UART 3 RX | UART 3 TX |
| Device Port Pin | D9 | D10 | F4 | F5 | D3 | D4 | D5 | G8 | G7 | G6 | E0 | E1 | E2 | F3 | F4 | F5 | F0 | F1 | D0 | D1 | G9 | G8 | G7 | G6 |
| App Developer Slave Peripheral Pin | PWM 0 | PWM 1 | PWM 2 | PWM 3 | PWM 4 | PWM 5 | PWM 6 | PWM 7 | PWM 8 | PWM 9 | PWM 10 | PWM 11 | PWM 12 | PWM 13 | PWM 14 | PWM 15 |
| Device Port Pin | D0 | D1 | D2 | D3 | D4 | D5 | D6 | D7 | F0 | F1 | F3 | F4 | F5 | E0 | E2 | E4 |
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
| IOGetInputPin | |
| Pin | |
| Range: 0-47 ... Pin 34 unimplemented | |
| ADCSample8 | |
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-31 ... Channels 16-23 unimplemented | |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| RegisterWrite | |
| Writes to one of the registers on-board the device | |
| RegisterAddress | |
| The address of the register | |
| Data | |
| The data value to assign to the register | |
| RegisterRead | |
| Read one of the registers on-board the device | |
| RegisterAddress | |
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-15 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| ADCSetReferenceVoltage | |
| Specified the reference setting for ADC reads. | |
| RefType | |
| 0=AREF, 1=VCC, 3=Internal 1.1V | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| ADCSample12 | |
| Reads the voltage present on an Analog pin as an 12-bit value range 0-4095 | |
| ADCChannel | |
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-15 | |
| Duty | |
| IOSetOutputPin | |
| Pin | |
| State | |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0-15 | |
| Prescaler | |
| Period | |
| Default 255 | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-15 | |
| I2CInitialise | |
| Channel | |
| Baud | |
| IOGetInputPin | |
| Pin | |
| ADCSample8 | |
| ADCChannel | |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| RegisterWrite | |
| RegisterAddress | |
| Data | |
| RegisterRead | |
| RegisterAddress | |
| I2CRestart | |
| Channel | |
| PWMDisable | |
| Channel | |
| Range: 0-15 | |
| I2CStart | |
| Channel | |
| SPITransfer | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Channel | |
| Last | |
| I2CStop | |
| Channel | |
| RefType | |
| SPIPrescaler | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| ADCSample12 | |
| ADCChannel | |
| PWMSetDuty | |
| Channel | |
| Range: 0-15 | |
| Duty | |
| IOSetOutputPin | |
| Pin | |
| State | |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Channel | |
| Range: 0-15 | |
| Prescaler | |
| Period | |
| Default 255 | |
| PWMEnable | |
| Channel | |
| Range: 0-15 | |
