| Author
Matrix Ltd.
| Version
1.4
| Category
Wireless
Bluetooth (RN4677) component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_RN4677.fcfx
ReceiveByte
| Receives a single data byte from the Bluetooth module. 0-255 - Valid Data / 256 signifies no data available.
- UINT
Timeout
| Amount of time to wait in milliseconds 0=Wait forever
- UINT
SendString
| Sends a string to the Bluetooth module.
- STRING
Text
- BYTE
SendCR
LeaveCommandMode
| Leaves command mode allowing data to be passed back and forth,
ConnectToMAC
| Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful.
- STRING
MACAddress
| MAC Address of the Bluetooth Device we wish to connect to
- BOOL
SendCommand
| Sends a command string to the Bluetooth module. 0 = Command sent ok, 255 = No Reply
- STRING
Command
- BYTE
SendCR
- BYTE
DiscardReply
| 0=Do not touch the reply, 1=Wait for reply and remove from buffer
- BYTE
ReadString
| Copies the incoming data from the data string array to a local string variable.
- BYTE
NumBytes
| Maximum number of bytes to try and read
- STRING
SendByte
| Sends a single data byte out to the Bluetooth module.
- BYTE
Data
EnterCommandMode
| Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK
- BOOL
WaitForStringValue
| Allows us to wait and check for an incoming value. Returns 1 if the string value is found otherwise returns 0.
- STRING
Value
| String value to look for
- UINT
Timeout
| Length of time to wait in milliseconds
- BOOL
GetMACAddress
| Gets the local Bluetooth device MAC address.
- STRING
| Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply.
- BYTE
Bluetooth Settings
Init Details
| Allows the Bluetooth device name and key to be automatically assigned on initialise.
Device Name
| Sets the friendly name of the Bluetooth device.
Pair Key
Discoverable
| Is the Bluetooth module discoverable by default?
Reply Timeout
| Specifies the amount of time to wait for incoming data before timing out in milliseconds. Default 2000 = 2 seconds.
RX Buffer Size
| Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module. Default 40
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
Reset Pin
Simulate Comms
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
ReceiveByte
- UINT
Timeout
- UINT
SendString
- STRING
Text
- BYTE
SendCR
LeaveCommandMode
ConnectToMAC
- STRING
MACAddress
- BOOL
SendCommand
- STRING
Command
- BYTE
SendCR
- BYTE
DiscardReply
- BYTE
ReadString
- BYTE
NumBytes
- STRING
SendByte
- BYTE
Data
EnterCommandMode
- BOOL
WaitForStringValue
- STRING
Value
- UINT
Timeout
- BOOL
GetMACAddress
- STRING
- BYTE
Bluetooth Settings
Init Details
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
