Component: LED (BL0167) (E-blocks 2)
| Category | E-blocks 2 |
LED component
LED component to drive the E-blocks 2 BL0167 LED board. Provides eight individually addressable LEDs.
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_LED_BL0167.fcfx
| BarGraph | |
| Turns on the first N elements of the array - for generating bar graph metes etc. | |
| Length | |
| How many items to light up. Range 0-8 | |
| LEDOn | |
| Turns on the selected LED leaving the other LEDs as was. | |
| Index | |
| LED to switch on. Range: 0-7 | |
| AllOn | |
| Switches On All LEDs. | |
| LEDOff | |
| Turns off the selected LED leaving the other LEDs as was. | |
| Index | |
| LED to switch off. Range: 0-7 | |
| PointGraph | |
| Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range. | |
| Index | |
| The LED to light. Range: 0-7 | |
| WriteValue | |
| Write a number which is presented on the LEDs in binary. | |
| Value | |
| Value to write to the LEDs. Range: 0-255 | |
| AllOff | |
| Switches Off All LEDs. | |
| Properties | |
| Output Mode | |
| Port | |
| Colour | |
| BarGraph | |
| Length | |
| LEDOn | |
| Index | |
| AllOn | |
| LEDOff | |
| Index | |
| PointGraph | |
| Index | |
| WriteValue | |
| Value | |
| AllOff | |
| Properties | |
| Output Mode | |
| Port | |
| Colour | |
