Component: Data Transfer (API I2C) ()
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category |
Data Transfer (API I2C) component
Comms data injector to allow a I2C bus peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical I2C bus.
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADAI2C.fcfx
InitialiseInjector | |
Sets up the injector ready to receive commands or send data | |
- STRING | InjectorName |
Name of the console that will be created | |
- BYTE | Return |
TxByte | |
Puts a byte onto the comms channel. | |
- BYTE | DataByte |
- VOID | Return |
RxByte | |
Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available | |
- UINT | Return |
GetConsoleHandle | |
Gets the handle to the console allowing data displaying on the panel etc. | |
- HANDLE | Return |
Properties | |
SCADA Slave | |
SCADA Slave component to use to pipe data to a physical SPI bus |
- BYTE | Return |
TxByte | |
- BYTE | DataByte |
- VOID | Return |
RxByte | |
- UINT | Return |
- HANDLE | Return |
Properties | |
SCADA Slave | |
