Component: Switch Push Button (Switch)
Author | Matrix TSL |
Version | 1.0 |
Category | Switch |
Switch Push Button component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
WaitUntilHigh |
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity | |
Return |
SetState |
Sets the switch to be on or off. | |
State |
The new state of the switch (true=on, false=off) | |
Return |
WaitUntilLow |
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity | |
Return |
Properties |
Switch Settings |
Connection |
Polarity |
Debounce |
Latching |
Label |
Component Label |
Label Colour |
Show Connection Label |
Show Pin Value |
Appearance |
Style |
Type |
On Label |
Off Label |
WaitUntilHigh |
Return |
SetState |
State |
Return |
WaitUntilLow |
Return |
Properties |
Switch Settings |
Connection |
Polarity |
Debounce |
Latching |
Label |
Component Label |
Label Colour |
Show Pin Value |
Appearance |
Style |
Type |
On Label |
Off Label |
