| Author
Matrix Ltd.
| Version
2.0
| Category
Comms: Networking
TCP/IP (WIZ810MJ W5100) component
TCP/IP component designed to work with the WIZ810MJ module or W5100 IC from Wiznet, as used on version 2 EB023 E-block and the MIAC Industrial Addon module.
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_WIZ810MJ.fcfx
TxSendMyIP
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
  - BYTE
| Specifies the communications channel 0-3
RxMatchMyIP
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
  - BYTE
  - BYTE
RxMatch_4_Bytes
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters.  There are similar functions that check for 2 bytes and 6 bytes.
  - BYTE
  - BYTE
Byte1
| Specifies the value of the first byte
  - BYTE
Byte2
| Specifies the value of the second byte
  - BYTE
Byte3
| Specifies the value of the third byte
  - BYTE
Byte4
| Specifies the value of the fourth byte
  - BYTE
SetMyIP
| This macro sets up the Internet E-Block's own IP address.  In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
  - BYTE
IP0
| First Byte of IP address
  - BYTE
IP1
| Second Byte of IP address
  - BYTE
IP2
| Third Byte of IP address
  - BYTE
IP3
| Fourth Byte of IP address
TxSendString
| This macro fills the specified channel's transmit buffer with data.  It can fill the buffer with a string of information.
  - BYTE
  - STRING
Data
| Data byte to append to Tx buffer.
  - BYTE
Length
RxReadHeader
| Once data in a particular channel has been received, the header will be filled with information about the received data.  This macro will return the information in the header.  The idx parameter specifies which byte of information in the header to read
  - BYTE
  - BYTE
Idx
| Specifies the byte index to return
  - BYTE
RxSkipBytes
| Often when receiving data packets, it may be necessary to ignore large sections of the data.  This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
  - BYTE
  - BYTE
Count
| Specifies how many bytes to skip
MIAC_Module_SetData
  - BYTE
Count
  - BYTE
D0
  - BYTE
D1
  - BYTE
D2
  - BYTE
D3
  - BYTE
D4
  - BYTE
D5
CreateIPSocket
| Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3.  Note that sockets with different modes can be opened on different channels.
  - BYTE
  - BYTE
Protocol
| Specifies which IP protocol to use
  - BYTE
Broadcast
| Allows broadcast type packets to be sent and received
  - BYTE
SetDestination
| This is used in IP and UDP modes to set the destination of the intended data transfer.  The destination IP address needs to be set for both IP and UDP modes.
  - BYTE
  - BYTE
Dst_IP0
| Specifies the first byte of an IP address
  - BYTE
Dst_IP1
| Specifies the second byte of an IP address
  - BYTE
Dst_IP2
| Specifies the third byte of an IP address
  - BYTE
Dst_IP3
| Specifies the fourth byte of an IP address
  - UINT
Dst_Port
| Destination Port
  - BYTE
MIAC_Module_GetData
  - BYTE
Index
  - BYTE
TxStart
| This macro indicates the start of data transmission for the specified buffer.  In TCP mode, data transmission can only begin once the socket has become established.  In other modes, data transmission can occur as soon as the socket has been opened.
  - BYTE
MIAC_Module_Message
  - UINT
CAN_ID
  - UINT
CMD_ID
  - BYTE
RxReadByte
| A call to this macro will return a byte of data in the reception buffer of the specified channel.  It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
  - BYTE
  - BYTE
CreateUDPSocket
| This macro creates a socket for sending and receiving UDP data.
  - BYTE
  - UINT
Src_Port
| Port Number
  - BYTE
RxMatch_6_Bytes
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters.  There are similar functions that check for 2 bytes and 4 bytes.
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
Byte3
  - BYTE
Byte4
  - BYTE
Byte5
| Specifies the value of the fifth byte
  - BYTE
Byte6
| Specifies the value of the sixth byte
  - BYTE
RxMatch_2_Bytes
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters.  There are similar functions that check for 4 bytes and 6 bytes.
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
TxEnd
| Once the transmit buffer has been filled with data, call this macro to actually send the data.
  - BYTE
RxReadString
| A call to this macro will return a string of data in the reception buffer of the specified channel.  It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
  - BYTE
  - BYTE
Length
  - STRING
CreateTCPSocket
| This macro creates a socket for sending and receiving TCP data.
  - BYTE
  - UINT
Src_Port
| Port Number
  - BYTE
RxDataAvailable
| This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received.  A positive return value indicates that data is available.
  - BYTE
  - BYTE
MIAC_Module_PushData
  - BYTE
Data
TxSendByte
| This macro fills the specified channel's transmit buffer with data.  It can fill the buffer with a single byte of data, or with a string of information.
  - BYTE
  - BYTE
Data
TCPListen
| This macro puts a previously opened TCP channel in "passive open" mode.  This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
  - BYTE
TxSendByte_Sim
  - BYTE
  - BYTE
Data
RxFlushData
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
  - BYTE
TCPConnect
| This macro puts a previously opened TCP channel in "active open" mode.  This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
  - BYTE
  - BYTE
Dst_IP0
  - BYTE
Dst_IP1
  - BYTE
Dst_IP2
  - BYTE
Dst_IP3
  - UINT
Dst_Port
| Destination Port
  - BYTE
RxReadByte_Sim
  - BYTE
  - BYTE
RxMatchMyMAC
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
  - BYTE
  - BYTE
RxFlushData_Sim
  - BYTE
RxDataSize
| This macro is used to detect the size of data collected by the Rx_data_available macro.
  - BYTE
  - UINT
CreateMACSocket
| This macro creates a socket for sending and receiving Ethernet data using raw data.
  - BYTE
Promiscuous
| Receive everything (1) or just data bound for your MAC (0)
  - BYTE
Broadcast
| Allows broadcast messages to be accepted (1) or rejected (0)
  - BYTE
Error
| Allowsmessages with errors to be accepted (1) or rejected (0)
  - BYTE
CreateUDPSocket_Sim
  - BYTE
  - UINT
Src_Port
| Port Number
  - BYTE
TxSendMyMAC
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
  - BYTE
SetMACAddress
| This macro sets up the Internet E-Block's MAC address.  In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
  - BYTE
MAC0
| First Byte of address
  - BYTE
MAC1
| Second Byte of address
  - BYTE
MAC2
| Third Byte of address
  - BYTE
MAC3
| Fourth Byte of address
  - BYTE
MAC4
  - BYTE
MAC5
| Fifth Byte of address
RxMatch_4_Bytes_Sim
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
Byte3
  - BYTE
Byte4
  - BYTE
RxDataSize_Sim
  - BYTE
  - BYTE
SetSubnetMask
| This macro sets up the Internet E-Block's Subnet Mask.  In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
  - BYTE
IP0
  - BYTE
IP1
  - BYTE
IP2
  - BYTE
IP3
RxMatch_2_Bytes_Sim
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
RxMatchMyMAC_Sim
  - BYTE
  - BYTE
TCPClose
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
  - BYTE
GetSocketStatus
| This returns the state of the requested channel's socket.
  - BYTE
  - BYTE
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros
  - BYTE
SetGateway
| This macro sets up the Internet E-Block's Gateway address.  In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
  - BYTE
IP0
  - BYTE
IP1
  - BYTE
IP2
  - BYTE
IP3
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin  Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Sim Type
| Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
TCP Simulation
Network Interface
| List of network interfaces connected to the PC.  Sets which interface we are communicating via.
TxSendMyIP
  - BYTE
RxMatchMyIP
  - BYTE
  - BYTE
RxMatch_4_Bytes
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
Byte3
  - BYTE
Byte4
  - BYTE
SetMyIP
  - BYTE
IP0
  - BYTE
IP1
  - BYTE
IP2
  - BYTE
IP3
TxSendString
  - BYTE
  - STRING
Data
  - BYTE
Length
RxReadHeader
  - BYTE
  - BYTE
Idx
  - BYTE
RxSkipBytes
  - BYTE
  - BYTE
Count
MIAC_Module_SetData
  - BYTE
Count
  - BYTE
D0
  - BYTE
D1
  - BYTE
D2
  - BYTE
D3
  - BYTE
D4
  - BYTE
D5
CreateIPSocket
  - BYTE
  - BYTE
Protocol
  - BYTE
Broadcast
  - BYTE
SetDestination
  - BYTE
  - BYTE
Dst_IP0
  - BYTE
Dst_IP1
  - BYTE
Dst_IP2
  - BYTE
Dst_IP3
  - UINT
Dst_Port
| Destination Port
  - BYTE
MIAC_Module_GetData
  - BYTE
Index
  - BYTE
TxStart
  - BYTE
MIAC_Module_Message
  - UINT
CAN_ID
  - UINT
CMD_ID
  - BYTE
RxReadByte
  - BYTE
  - BYTE
CreateUDPSocket
  - BYTE
  - UINT
Src_Port
| Port Number
  - BYTE
RxMatch_6_Bytes
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
Byte3
  - BYTE
Byte4
  - BYTE
Byte5
  - BYTE
Byte6
  - BYTE
RxMatch_2_Bytes
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
TxEnd
  - BYTE
RxReadString
  - BYTE
  - BYTE
Length
  - STRING
CreateTCPSocket
  - BYTE
  - UINT
Src_Port
| Port Number
  - BYTE
RxDataAvailable
  - BYTE
  - BYTE
  - BYTE
Data
TxSendByte
  - BYTE
  - BYTE
Data
TCPListen
  - BYTE
TxSendByte_Sim
  - BYTE
  - BYTE
Data
RxFlushData
  - BYTE
TCPConnect
  - BYTE
  - BYTE
Dst_IP0
  - BYTE
Dst_IP1
  - BYTE
Dst_IP2
  - BYTE
Dst_IP3
  - UINT
Dst_Port
| Destination Port
  - BYTE
RxReadByte_Sim
  - BYTE
  - BYTE
RxMatchMyMAC
  - BYTE
  - BYTE
RxFlushData_Sim
  - BYTE
RxDataSize
  - BYTE
  - UINT
CreateMACSocket
  - BYTE
Promiscuous
  - BYTE
Broadcast
  - BYTE
Error
  - BYTE
CreateUDPSocket_Sim
  - BYTE
  - UINT
Src_Port
| Port Number
  - BYTE
TxSendMyMAC
  - BYTE
SetMACAddress
  - BYTE
MAC0
  - BYTE
MAC1
  - BYTE
MAC2
  - BYTE
MAC3
  - BYTE
MAC4
  - BYTE
MAC5
RxMatch_4_Bytes_Sim
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
Byte3
  - BYTE
Byte4
  - BYTE
RxDataSize_Sim
  - BYTE
  - BYTE
SetSubnetMask
  - BYTE
IP0
  - BYTE
IP1
  - BYTE
IP2
  - BYTE
IP3
RxMatch_2_Bytes_Sim
  - BYTE
  - BYTE
Byte1
  - BYTE
Byte2
  - BYTE
RxMatchMyMAC_Sim
  - BYTE
  - BYTE
TCPClose
  - BYTE
GetSocketStatus
  - BYTE
  - BYTE
  - BYTE
SetGateway
  - BYTE
IP0
  - BYTE
IP1
  - BYTE
IP2
  - BYTE
IP3
Prescale
MOSI
MISO
CLK
CS / SS
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Sim Type
TCP Simulation
Network Interface
